did hydrostream build a open bow v hull
Re: did hydrostream build a open bow v hull
Londo, that's not a v-bottom. That is an xt. Very nice one thought.
There, Fixed it so the pic shows up. Lucky, I hear them hulls can really move when set up right. Hows that thing been for ya so far?
I have a 91 Valero YT.. Just bought it this spring and love it... my wife does too .
I did see a really sweet one available at autotrader.ca by doing a Hydrostream search in Ontario
Good luck.. you'll love it when you find one.
- Pic 1.jpg (323.8 KiB) Viewed 11361 times
- Pic 2.jpg (234.82 KiB) Viewed 11361 times
Correct me if I am wrong but that looks to me like a V-Bottom and not a YT.Kramerica wrote:I have a 91 Valero YT.. Just bought it this spring and love it...
Look at the bottom of this Valero. That is a YT Hull. The V-Pad has the VKing bottom.
You got yourself a V-Bottom there and not a YT. SWEET!!!!
I agree Hippie. BillHippie459MN wrote:You got yourself a V-Bottom there and not a YT. SWEET!!!!
You are right, definately a V bottom.... Still trying to figure out the models. When I look at the descriptions, I am not sure if it is a Valero or a Vasseret. I see the Canadian Editions are different than the others. I just went by whant the guy at the marina called it. It was a huge improvement over the one I had before.
Here ya go....
Hope that helps.The Valero YT Bowrider and Vasseret YT were the same; the boat was called the former from late 1986 to late 1988 and it was called the Vasseret from '89 on. The V-bottom version was introduced in 1990 again being called the Vasseret V-bottom. The Canadian Edition version is different; they never had a YT version, and their deck was markedly different than the original U.S. HydroStream model.
The Vasseret used the Viking hull. Interesting story about the V-bottom version. Some of the workers at HydroStream wanted to build one, but Pipkorn said no because he thought it wouldn't work; he felt the open bow would never fit and work with the hooked nose construction. While Pipkorn went off on vacation, the workers went ahead and built one using their own money. The result showed that it did work, and very nicely. The Vasseret was a huge success and became HydroStream's second best seller.
- 2590 Views
Sep 05, 2011 6:17 pm
- 7867 Views
- Last post by Bad_Influence
Sep 06, 2011 12:43 pm
- 2474 Views
Sep 06, 2011 10:17 am
- 2636 Views
Sep 06, 2011 10:58 am
- 4551 Views
Sep 06, 2011 10:28 pm
