'82 Vandal Floor and Recore
varmint1
Re: '82 Vandal Floor and Recore
Post: # 10994Post varmint1 »
YDOC462 wrote:Man that looks great! Looks like u knew what u were doing! U had that varmit in the water yet?
I only knew what I was doing because of this GREAT FORUM and GREAT MEMBERS that dont mind answering questions, thanks guys! Yeah I had the Varmint out at the lake the last time I was home, still tweaking on it. :up:
Post: # 10996Post Hippie459MN »
varmint1 wrote:I only knew what I was doing because of this GREAT FORUM and GREAT MEMBERS that dont mind answering questions, thanks guys! Yeah I had the Varmint out at the lake the last time I was home, still tweaking on it. :up:
PICTURES!!! Glad t hear ya got it on the water. :up:
varmint1
Post: # 11001Post varmint1 »
I made some more progress today, didnt get much done yesterday, had to bring my children to the Circus. Started off by dry tabbing in the inside of the stringers, then dry fitted the core,bedded them in and sealed them up.
100_0620 (Copy).JPG (193.64 KiB) Viewed 27154 times
filled all voids around transom with cab-o-sil
tabbed transom
100_0621 (Copy).JPG (204.16 KiB) Viewed 27154 times
100_0623 (Copy).JPG (259.6 KiB) Viewed 27154 times
100_0622 (Copy).JPG (226.22 KiB) Viewed 27154 times
100_0624 (Copy).JPG (232.63 KiB) Viewed 27154 times
Pictures are out of order :thinking:
Post: # 11068Post YDOC462 »
Looking good man!
Post: # 11082Post 77viper »
YDOC462 wrote:Looking good man!
Yep I agree :up:
varmint1
Post: # 13437Post varmint1 »
A question to anyone who has done more glass work than me. Do I need to grind the glass that I already have already laid before I glass anymore, since the last time I worked on it was in August. Patrick
Post: # 13438Post 77viper »
Yes just a light grind to get the fibers on the top.
Post: # 13470Post VultureNo2 »
Looks good. You're getting there. Bill :up:
varmint1
Post: # 13477Post varmint1 »
Thanks Bill, hope to get some more work done on it as soon as I get back home
alaskastreamin
Been thanked: 158 times
Post: # 13530Post alaskastreamin »
Looking good there. :up: Nice clean work!!!
One thing I noticed that might help. "prime" the wood with resin and let dry before you glass to it. If not, the wood will soak in the resin and pull it away from the fiberglass. You will know this is happening if you see white spots appear after it dries. This also applies to the Balsa. (seals the end grain)
I actually add a "splash" of acetone to allow it to penetrate the wood deeper. You can double the hardner for this part if you want.
Keep the pictures coming. We ALL like pictures. :mrgreen:
