Hi, Just got a Voyager,1984, with 89 200 yamaha. I'm an old guy wanting to have a little fun and not kill myself and maybe still use it to pull grand kids on a tube. Wanting some info and advice if possable. Now it has an alum. prop 21 pitch. Want a SS one and want to know what you guys think. I've read 3 blade better for beginner and 4 is better??? Has a powered jack plate that is not set back any. Also want driving advice. If you go solo do you need ballast weight on pass. side to be safe or not. One guy told me first time I take it out have someone in other seat? I'm a big guy 6'3 275lbs.
Any and all help appreceated. Thanks
MY FIRST
Re: MY FIRST
Welcome Wolfie. I think a 23 pitch 4 blade would make an excellent all-around prop. There may be better out there as I'm no expert. It'll snatch a skier, prob run 65+, and get good fuel economy. You dont have to have ballast for a high speed run, although the boat will be easier to handle. You really need an experienced pad-v driver with you to show you what to do. It takes time and practice, but you will get it. Just dont drive beyond your skills, or you may get wet!-Scottwolfie wrote:Hi, Just got a Voyager,1984, with 89 200 yamaha. I'm an old guy wanting to have a little fun and not kill myself and maybe still use it to pull grand kids on a tube. Wanting some info and advice if possable. Now it has an alum. prop 21 pitch. Want a SS one and want to know what you guys think. I've read 3 blade better for beginner and 4 is better??? Has a powered jack plate that is not set back any. Also want driving advice. If you go solo do you need ballast weight on pass. side to be safe or not. One guy told me first time I take it out have someone in other seat? I'm a big guy 6'3 275lbs.
Re: MY FIRST
Welcome to the forum, and the hydrostream madness.
I have no experience with a voyager but I think the bottom is similar to a vegas, so a 24 trophy should be a good all around prop.
Before getting all you can out of the boat make sure it's set up safely. You should have dual cable steering, solid motor mounts and a foot throttle. These will make it easier and safer to drive. Also I recommend everyone at lest check their core.
As for driving you will be fine by yourself without ballast. Run it up to 65 that's wen it's getting up on the pad and the chine walking will start. Once it starts back off a bit and then speed up, you will start to get comfortable with the feeling and learn what to expect. After you are comfortable with it you can start to control the chine walk be counter steering in quick movements opposite of the way the hull is leaning. Getting the hang of it will take time but be patient, once you get it you will be correcting it and not even know it.
Re: MY FIRST
Thanks for the welcome and advice. What's the best way to check the core? The guy I bought it off of said he did and it was good at that time which was about 3 years ago.
Dave
Dave
- 3331 Views
Jun 17, 2010 4:46 am
- 4858 Views
- Last post by LSaupe
Jun 16, 2010 6:48 pm
- 5387 Views
Jun 18, 2010 6:06 am
- 6597 Views
- Last post by Edseler8
Jun 21, 2010 6:09 am
- 5885 Views
Jun 18, 2010 10:23 am
