trim ? for 77 viper
trim ? for 77 viper
One of my trim cylinders is leaking a little where the cylinder threads into the clamp. I have the old style where the hydrolics run through the bottom bolts. both cylinders were kinda loose and I snugged them up but the one still seeps. I have a manual but it don't cover this clamp! What am I in for???
Rick.
Rick.
Re: trim ? for 77 viper
What pump is it? I'm guessing a 3 ram, the only manual I have here now is for the newer 3 ram and it doesn't have any external lines.
If it's the stock pump list your ser# and I can look at a parts breakdown to see where you are talking about, I can't picture it in my head.
Ok I see your running a single with your pump in the boat. Is it leaking at the fitting where the hyd line goes into the cyl?
If it is tilt iap and use the tilt lock or something so it can't come down. Remove the line and look for junk or a bad o'ring it shouldn't be bad to fix. I'll look into it a little more tomorrow at work.
It's old. Before the bolt pattern (BIA) standards. I'll send you the ser # tomarrow. It's a 2 ram setup and the fluid runs through the bottom transom mounting bolts. Thanks, Rick
So is it leaking from the lines? or the actual cyl?
It's leaking where the cylinder screws into the clamp. It's kinda hard to explain. I'll snap a pic of it and send it with the ser #. Thanks
Alright, the ser # is 4967268
the fluid seeps up through the threads where the cylinder screws into the bracket.
I think I found what p/n the cylinder is. It looks like that clamp was used on the XR2's back then. The cylinder p/n is 79114a4. I'm sure it's just an o-ring in there. I double checked my manual and nothing like it.
I looked at a paqrts brake down and didn't see any parts available for the cly just a complete one for a tad over 750.
Wow. Thats what I was afraid of. I'll take it apart and see whats in there. I don't look hard. Prop the motor up and it looks like it'll come right out of there. Well, thanks for lookin into it. Don't look like any shake down weather very soon here. Rain wind and more rain.
Rick.
Rick.
- 3829 Views
- Last post by frogII
Oct 11, 2011 8:42 pm
- 3721 Views
- Last post by Dmick
Dec 08, 2011 5:06 pm
- 8543 Views
Oct 12, 2011 5:18 pm
- 4620 Views
- Last post by Killer
Dec 11, 2011 10:07 am
- 3226 Views
Oct 15, 2011 1:41 am
Users browsing this forum: No registered users and 0 guests
