Chine walking problem
Re: Chine walking problem
Can you post a picture of the gearcase? I'm thinking the fairing on it has a problem.
How loose are the motor mounts? Does the engine move around much at speed?
Do you know what brand of steering it has?
The boat should run near 70 as it is.
I am having trouble downloading pictures. Says file is too big. Steering is dual Ride Guide. Little to no play. Mounts seem pretty tight, not much play. Factory mounts.is it possible a jack plate is needed or just going up in mounting holes?
I ran 70+ with an inline without a jackplate. Jackplates are for V-6's, you can't put a V-6 setup in an inline powered boat, the needs are totally different.
Might need a prop with more bowlift, excessive positive trim will induce chine walk. I like a 26" small ear Chopper for that combo.
Thanks for info. I will try to send pictures . Maybe you can see the problem
- 15Replies
- 10790 Views
- Last post by shellyisland
Mar 21, 2010 9:11 pm
- 11162 Views
- Last post by hydrohellion
Mar 15, 2010 8:06 pm
- 5347 Views
- Last post by hydrostream76
Mar 10, 2010 5:52 am
- 31Replies
- 35604 Views
- Last post by LSaupe
Apr 04, 2011 6:05 pm
- 6948 Views
Mar 11, 2010 8:03 pm
