need more motor height help!?!?
i got my jack plate high as i can be mounted on transom it has 4 inchs of travel my center of prop shaft is even to slightly below bottom of pad i need to be around a inch or so higher for my 30 cleaver to perform any way to make it go higher
Re: need more motor height help!?!?
If the motor is as high as possible mounted on jack then that's it. You'll have to look for another jack plate with more lift. You MIGHT get away with bolting a 1/2" thick aluminum plate to the jack extending up another 1 1/2" and bolting the motor to that. You would want to keep an eye on the plate to make sure it doesn't bend.
yea all the jack plates i found was only like 4 inch of travel as thats what i have now iam starting a 260hp bp soon with a 15inch offshore mid then my jack plate would be plenty high at that point my use ur suggestion for the time being thanks hows the last virage coming along
Got the tank, floor and transom in over mothers day. Going back to property July 26 for 10 days. May be too hot to do much then but will be back in Oct. for two weeks. Will glass deck to hull and start building interior next. All hard parts for motor are bought.
Just sold Viper last week. Waiting on check to arrive and clear before ordering jack plate and gauges.
Next summer I want to be in the water.
cool deal how far is the virage from you in alaska
It's in eastern Washington and Sitka is just above Seattle, off the coast of Canada.
It's 102* there today and Sitka is 62* and drizzling. Whoo Hooo!!!!
take an 11/2" off the bottom of the boat..... then prop shaft will be where you want it.
Ron we want pics!
vertex pistons on the way!!! whoohoo!
highjack over....cody out.
Ron we want pics!
glad you got the pistons now put it together come to tn and lets run em lol redrider in the pysco billy cadialliac out
- 8088 Views
Nov 29, 2011 11:25 am
What can happen when your Hydrostream has a rotten core
Last post by Hippie459MN « Nov 29, 2011 10:30 pm - 8Replies
- 20703 Views
- Last post by jacklake2003
Dec 06, 2011 11:55 am
- 14077 Views
Dec 19, 2012 8:12 pm
- 8057 Views
- Last post by silkeysak
Dec 02, 2011 6:29 pm
- 18Replies
- 10615 Views
- Last post by ConFuseee
Jan 24, 2012 7:31 pm
