seastar steering question?
i just installed a teleflex seastar system and have a small concern. i read/watched a vid. in another thread where that person had some air left in his lines and you could visually see him steering right more than left as he corrected the boat.
i set mine up, bled the system (to what i thought was good), indexed the wheel. im unable to budge the motor side to side, no leaks, theres about an 1/2" play in wheel.(maybe less) is this normal? (never dealt with hydro steering before)
i ran the boat a few times and noticed the wheel has worked itself halfway around. so then thinking i had air in line i bled again getting very very minimal air out on one side.
indexed the wheel again and ran only to get same results. is this normal?? does the system work itself out at the beginning?? should i bleed again or index it and call it good?
my plans were to run it some more before bleeding and see what happens just thought id ask for advice or tips from yall first.
thanks
thanks
Re: seastar steering question?
russ, is the play in the wheel normal?
this boat i have is the 1st hydraulic I ve owned too,not sure.been wondering that myself
is yours staying indexed?
hydro steering is really good like on our offroad trucks no play at all on the outboards if all you have is 1/2 inch that seems good to me but your steering well no staying in the same postion seems like to me you mite have something loose on the helm steering well lock nut dont know if yours has a key in it to keep if from rotating if it does check to make sure its in there other than that air in the line shouldnt make your steering wheel change postions as if the motor is straight and u turn and come back straight now ur steering wheel is in diff postion beats me couldnt say i know the answer
Mine does not reindex either. I've been told it's normal. Matter of fact, if I trim too high while trailering, it'll work it's way over, all the way over to a hard turn position (even with the steering wheel secured). It has a bit of play too. My system is probably eight year old now and it's been like this for as long as I have owned it. Ha, except for these two issues, it's perfect.
thats what mine is doin tooSurface Scratcher wrote:Mine does not reindex either. I've been told it's normal. Matter of fact, if I trim too high while trailering, it'll work it's way over, all the way over to a hard turn position (even with the steering wheel secured). It has a bit of play too. My system is probably eight year old now and it's been like this for as long as I have owned it. Ha, except for these two issues, it's perfect.
- 3718 Views
Aug 18, 2012 8:10 am
- 6085 Views
- Last post by transomstand
Aug 29, 2012 8:03 am
- 6507 Views
Aug 19, 2012 9:11 pm
- 3881 Views
- Last post by Rut311969
Aug 17, 2012 7:45 am
- 6002 Views
Aug 20, 2012 6:03 am
