Not your average recore
Re: Not your average recore
Man Chet a lot of your pics have bikes in the back ground when do you find time to ride and man I want a mix and match 280 . You got any sleds? Oh yeah the boat
no looking good can wait to see it with the top finished carbon fiber top? .
Chet are you running a floor in the Vking or just stringers. Also on you Viper when you put your floor in did you fiberglass the bottom side?
Rut, most of the bikes are side jobs or storage for buddies, I used to be e bike mechanic until I broke my hip in a accident. I have a beater sled but haven't used it in a couple years. No carbon on the vking if I ever get time to work on it.
Varmint, I will not be putting a floor in the vking and when I put the floor in the viper I did use csm on both sides.
I needed a little motivation so I went to my storage shed and picked up the vking. It will be a couple days before I can start working on it but I guess it's some progress.
Allright a project mine will be stalled till spring . So I need a boat one to watch I gota finish a 71 elcamino I have takin up space .
A long time ago I had a 72 El Camino,Forest Green with white ss stripes , 396 , 4 speed, it was brand newRut311969 wrote:Allright a project mine will be stalled till spring . So I need a boat one to watch I gota finish a 71 elcamino I have takin up space .
Stop it russ, Your showing your age.
Well I finally started to make some progress on the vking, no where near where I want to be but if I can keep at it I should be done by spring.
I picked up a nice 200 case and started with a bobs cone and added a custom touch. It's notched for a 15" so it will clear the ram.
I didn't like the look of the rubber hose so I decided to weld in a pipe instead.
I picked up a 260 cowl since my alien is being repaired, I'm not sure which one to use I guess I will have to see what they look like once the top is done.
I pulled the mid back off and cut the transom that I had built up for the 20" mid, I'm going to pick up a 15" this coming week.
I went to work on the dash, once that is done I can work on the steering. I will be using cable and wing-plate steering and I figure it will be a lot easier to install the pullies before I cover the deck.
My template made from 1/2" foam, so nice to cut and shape.
The tach is a little low but I need to be able to see over it. I can still see from 4000 up so that is what is important, that and it's a play back tach so I can see what is going on after the race.
- 91876 Views
- Last post by Calhydro
Sep 15, 2018 6:58 pm
- 259393 Views
- 196855 Views
- 231630 Views
- 193435 Views
