![Boating :boating:](./images/smilies/boating.gif)
water pressure gauge
how do i hook up water psi gauge ? tap into hose going to piss stream where it exits block and what king of hardware is needed have livorsi gauge ![Boating :boating:](./images/smilies/boating.gif)
Re: water pressure gauge
What engine? On my merc, there is a fitting on the top of the block rearward of the flywheel.
On my Johnson I have it hooked up in the line going from the block to the tell tale (piss tube). Uses a simple T. Works well. There might be more optimum locations, but that is where mine was set up so I just left it there.
On V-6 loopers there is a brass nipple on the lower right (from the back). Remove the nipple and replace with the push in fitting that comes with the gauge, Just did mine last week. Good Luck!
- 3058 Views
May 11, 2010 4:21 pm
- 20Replies
- 14069 Views
- Last post by russelljwr
May 16, 2010 8:49 pm
- 3073 Views
May 11, 2010 5:04 pm
- 3661 Views
May 12, 2010 8:32 am
- 2940 Views
May 12, 2010 8:25 pm
