1977 Vulture Rebuild
- Has thanked: 358 times
- Been thanked: 83 times
Re: 1977 Vulture Rebuild
I will keep you posted but I will plan on Sat or Sun or both.
Hippie, I had spots in my bow like that also and I thought they were just thin, but they were all the way through and letting water into the balsa sandwich. Every time it would be in the water was causing damage and adding lots of water weight. I strengthened that with several layers of 50 before I even started the balsa layer and stuff. I will also re-glass from the outside when I get to that part. Good to see you making progress. Keep it up. Slow and steady gets it done too. Bill
Well, I had the chance to try out that grinding disk Chet has and be careful with it cause its like running a hot knife through a warm stick of butter. I love it and will be picking one up next week. If you actually seen the mess my boat is I would say I hot blot done today. I will have some pictures later.
I'm not giving up on it. Just lifes bumps along the way has kept me from being where it should but I am getting it done slowly but surly.
Well, I managed to get in about 3 hours of grinding yesterday at Chets place and used his steel grinding disk and what I got done would have taken me 8 hours with the paper disks.
It might not look like much but if you actually seen what I am working with you would understand.
Here is what I am having to grind away. The pictures don't really show how bad it really is.
I did a tiny bit up front but spent 99% of my time in the back.
And this is what happens when you get carried away with that grinding disk. That thing will melt right through your hull if your not careful. Notice the 2 holes.
I will be going and picking up one of them disks later this week and hopefully get more grinding done. That thing is worth every penny.
looks good hippie! i bet it feels good to finally get down to the clean hull. keep it up
Nice. Ah, the memories come flowing back. Keep grinding. The holes can be patched. Bill
I'm getting there. I wish I knew about that grinding disk long ago. I would have been a lot further if not about ready to start putting it back together.
my disc came in this weekend, gonna put it to work later this week.
Be careful with it, its will get away from you if your not careful and you will end up patchmg some holes like I will be.
is this that 20 ft that was on craiglist with the 300 merc on it?
1976 Viper Bicentenial
Currently Restoring..
- 8678 Views
Oct 26, 2009 6:55 pm
- 6946 Views
- Last post by markminden
Oct 26, 2009 12:50 pm
- 24Replies
- 17165 Views
- Last post by frogII
Oct 30, 2009 9:34 am
- 65Replies
- 166513 Views
- Last post by ScreaminVking78
Mar 21, 2011 10:59 pm
- 25701 Views
May 03, 2010 9:28 pm
