I just bought a 1974 Viper project.
I'll need information on the floor replacement and suppliers for materials needed. My plan is to use the colors of the 1976 bicentennial when I get that far. Any-one looking at my gallery can see the inside needs extensive work. I am an experienced auto restoration guy but this will be my first boat. I have most of the tools required and a friend you has worked on boats. Any step by step photos would be very helpful.
Chazz
- Been thanked: 6 times
Re: I just bought a 1974 Viper project.
i think express composites is close to you, many people use plywood for lots of builds on floor and stringers. balsa core in the hull, I used cabosil and resin to make radius and as a filler for some things.. if you plan on running a jackplate, you can just delete the splashwell and use balsa core to strengthen it. some use coosa board or nida core for the stringers or transom. I have a thread doing my viper, but im just a rookie. us composites has a good deal on epoxy resin and the glass I chose. used 17oz biaxial +/-45* double bias. works good for lots of stuff, a little thick though. good luck man, and post lots of pics!Ken Chaffee wrote:I'll need information on the floor replacement and suppliers for materials needed. My plan is to use the colors of the 1976 bicentennial when I get that far. Any-one looking at my gallery can see the inside needs extensive work. I am an experienced auto restoration guy but this will be my first boat. I have most of the tools required and a friend you has worked on boats. Any step by step photos would be very helpful.
Thanks my plan is a V4 120 Hp motor no jack plate. Mid to upper 60's is as fast as I need to go.
Chazz
that is very similar to my goals, but without a 15 inch mid, I have no way of getting the motor jacked up high enough to surface the prop. maybe I don't need to surface it though.... 120hp will go really good on these hulls. enough to be fun for sure. that is a very similar setup to my plans also. good luck!Ken Chaffee wrote:Thanks my plan is a V4 120 Hp motor no jack plate. Mid to upper 60's is as fast as I need to go.
You shouldn't need a 15" mid the transom is 20" unless your plan is to surface drive the motor. Most boats I have owned handled better with the motor at the standard height.
Chazz
that's the plan, looking for the most possible speedKen Chaffee wrote:You shouldn't need a 15" mid the transom is 20" unless your plan is to surface drive the motor. Most boats I have owned handled better with the motor at the standard height.
Make sure and take your time on the bottom work make it as strong as possible. Strength is safe.
Chazz
- 6305 Views
- Last post by maximum rpm
Aug 25, 2013 1:15 pm
- 18Replies
- 17007 Views
Jun 16, 2020 5:55 pm
- 3793 Views
Jul 05, 2013 1:25 pm
- 7733 Views
- Last post by Bayou Native
Feb 21, 2014 1:53 pm
- 3799 Views
Jul 05, 2013 4:41 pm
