Vking windshield mounting
How does the windshield attach at the rear? I have the frame and a windshield on the way. Is there a channel bracket of some kind that the frame attached to?
Re: Vking windshield mounting
There should be a notch in the deck that it sits into.
See the arrows in the picture. Click to enlarge the picture.
Hope that helps.
Hope that helps.
Yeah, I know...just screw through the rail into there? My rail has no holes.....
Yep. If there is no screw holes you have never had a windshield mounted to it before. Use a good stainless steel self tapping screw or something. Thats what I have but the have also been pre drilled and dont over tighten then so you dont wreck the fiberglass.
curious?...... Is this a new rail and shield...if so where did you get it.
there should be a block of wood glassed in behind the notched section.
It's a new rail from Hydrostrean in Tracy, CA purchased in 2000. The guy who bought it tried to install and broke the windshield they provided. Boat was sold to me with just the rail. i need a shield ....was going to go with acrylic but thinking epoxy now sice the guy broke the acrylic so easily.
Bruce
87 Vking YT, Yamaha ProV 150 now, 72 mph
BRAND NEW 1988 225+ Yamaha Excel going on, 85mph???
Bruce
OK, I got an acrylic windshield, however the shape isn't the same as the rail. How do I bend the rail to fit the windshield?
Windshield is flat across the top center but the rail is round like a horseshoe.....
got my fiberglass black gel coat version installed in oct /13 looks cool the rail sits inside the lip at the upper portion of the windshield and just added little silicone along with stainless trim screws its lower than stock besides the v king looks retarded with out the windshield the shipp cost was around 550.00 littl pricey but man its cool . i will try to get some snap shots soon. garyBQUICK wrote:It's a new rail from Hydrostrean in Tracy, CA purchased in 2000. The guy who bought it tried to install and broke the windshield they provided. Boat was sold to me with just the rail. i need a shield ....was going to go with acrylic but thinking epoxy now sice the guy broke the acrylic so easily.
Bruce
try sticking the top corners of windshield in first?
i had my winshield built buy scott steffe in flordia at all fiberglass repairs super clean and strong i run mine with no rail at all
- 1633 Views
Aug 28, 2009 10:57 pm
- 1408 Views
- Last post by hustle
Jul 14, 2009 7:20 pm
- 667 Views
Jul 14, 2009 7:03 pm
- 57Replies
- 13635 Views
Dec 31, 2013 5:29 pm
- 1075 Views
Jul 21, 2009 10:00 pm
