Here's a Screamandfly thread with pictures for those of you that want to keep up with my AE-21 project. At this point, the hull has been high speed wheeled with 3M finess bringing back most of the shine. The fuel tank and fittings on the tansom have been removed. The rear topdeck coring ply has been ripped out and the old transom knees have been ground away. I've got a little bit of sanding/grinding to do before I begin the carpentry on the new transom knees and rear topdeck braces. Once the transom is finished I'll be installing Panter 4" setback brackets, a Detwiler 8" All In One hyd. jackplate, and Bob's Machine Shop backing plates for the inside of the transom. The bilge will be sprayed with white bedliner for a clean finished look!!
http://forums.screamandfly.com/forums/showthread.php?t=214459
AE-21 Demolition and Resurection
1991 Canadian Edition AE-21/Merc 2.5
1997 Checkmate Pulsare 2100/under the knife
1994 Checkmate Pulsare 2100/Merc 225Xri-SOLD
1988 Valero YT Bowrider/Merc 175-SOLD
Re: AE-21 Demolition and Resurection
Sounds like a good plan. I will check out your other thread when I get in from the shop.
My new transom knees are finished and ready to be bonded to the transom, topdeck and center pod . The old knees were only 1/4" ply ...my new knees are 24lb density, 1 1/2" Coosa board. With 2 layers of 1708 Biax/Epoxy resin the new knees are 1 3/4" thick !! I won't be worrying about the transom after this mod!! Pictures are up on ScreamandFly..
A quick update for you guys...the transom knees are glassed in place, the bilge is now painted in white BilgeKote, the Panther 4" setback brackets are installed with Bob's Machine Shop alluminum backing plates. My 8" Detwiler Jackplate will be mounted this weekend. Livorsi gages will arrive this week also!
I have some new pictures up on Scream and Fly: http://forums.screamandfly.com/forums/showthread.php?t=214459
- 15Replies
- 8719 Views
- Last post by ggablehouse
Nov 22, 2014 11:55 am
- 4168 Views
Nov 25, 2014 2:24 pm
- 4851 Views
Dec 25, 2014 9:40 am
- 4393 Views
Jan 01, 2015 11:24 pm
- 6134 Views
- Last post by akmcneal
Mar 12, 2015 5:31 pm
