How are most of you holding down your covers? I have a new (to me - thanks Russ!) cover with edge loops for ropes or straps.
I do not wish to add snaps. What makes more sense, strap it down to the trailer, or to itself (side to opposite side)under the hull? Thinking of maybe sinch/pull straps with a release buckle under the hull.
Cover Hold Down Options?
Re: Cover Hold Down Options?
I tie it down with soft clothsline under the boat NOT tied to the trailer I loop the rope on one end and side the rope threw the loop then threw the rope loop and under the BOAT for each loop of the cover, or just call me and I ll xplain
This is same method I use .But I also use support pole in middle to make it shed water ect.
I make a loop on one end of the rope which always stays there,then I put the other end of the rope threw the loop on the cover and then threw the loop on the rope which always stays there , then i throw the rope with the just plan rope end under the boat NOT the trailer and then i put that end of the rope threw the other loop on that side of the boat . So the loopended rope is all on one side of the boat .I put the loopside rope on the open road side of the boat so if i have to tie or untie Im not on the side of the boat where the cars are driving
- 163547 Views
- 117322 Views
- 142169 Views
- 120364 Views
- 77004 Views
- Last post by msethsmile+
Dec 12, 2018 10:24 am
Users browsing this forum: No registered users and 68 guests
