1980 Hydrostream Vector
Re: 1980 Hydrostream Vector
Postby kytekeith » Jan 09, 2010 9:05 am
here are the stringers in a 76 vector Image Image
As you can see the floor level is lower then 80's and the stringers are only 2 inshes tall .
kytekeith
Images: 2
Postby micro48 » Jan 09, 2010 12:06 pm
Man that don't look like mine.Lets say the core is rotten in a couple of spots,what could happen if I did not replace?also someone has used anti-fowling paint on the hull,is there any way to sand or a chemical made to strip without harming gel coat.Looks like gel is good in spots where bottom paint has rubbed off
micro48
Images: 0
Postby kytekeith » Jan 09, 2010 7:18 pm
Any place the core is rotten a hard hit can crack the outer skin (hull): landing off a wave or hitting something in the water, or even while loading on the trailer. If someone put anti fouling paint on the bottom it would apear they left it in the water for long periods of time which would make a better chance for water to be able to get in the core. Image
This is a stress crack because of rotten core.
What have you done to check your core?
Man I would hate to see you have to pull the floor up later to recore and patch a crack in the hull!!!
kytekeith
Images: 2
Postby 77viper » Jan 09, 2010 10:55 pm
The water pressure alone will cause delamination and can make the boat hook or sink. Don't take the chance. If the core is wet it will rot, I wouldn't go through the trouble of only replacing part of the core do it all.
77 viper 2.4 200, 130 shot of NOS
91 vegas 2.5 svs acu fishing block
Hydrostream VIP
Hydrostream VIP
Images: 0
Postby micro48 » Jan 10, 2010 6:26 am
OK old core is comming out.This really is a nice boat,Hate to short cut anything.Thanks for the info.
micro48
Images: 0
Postby havingfun2 » Jan 10, 2010 7:42 am
:shock:
To properly prep for anti fowling the hull surface should be sanded to provide a course surface for the paint to stick.
IF this happened..( try stripping a small area to inspect) to remove all this paint, you might be left with yet another chore as the hull bottom will look like sh!t.
2002 Vegas V
1999 Erude 225 with everyday prop of 29p shooter
Just a fun ride all the way around.
havingfun2
Images: 0
Postby kytekeith » Jan 10, 2010 8:23 am
good morning Herbie, are you working on your boat today?
Have you taken a core sample?
I have ran across a few articles on what happens when water gets between the core and the glass and i have links to this info on my 76 vector restor thread you should read them.
kytekeith
Images: 2
Postby kytekeith » Jan 18, 2010 8:11 am
Hey Herbie , how is progress? Havn't heard from you lately, You didn't loose your keyboard did you?
kytekeith
Images: 2
Postby micro48 » Jan 18, 2010 3:46 pm
ok I cut 4 2"squares in the floor to check the core . When I took out the pieces of balsa they diddn't look rotten or water logged.I'm just going to patch the holes,put down a new floor.Repaint the bottom with some sort of epoxy,then its interior and Motor & controls.Gonna get a good chunk from IRS,Like to put 150 or 200HP on it,Jack plate,&foot throttle.I see some good deals on motors on ebay,will just have to see how it goes.What works best on that boat as far shaft lenght goes.I think the 115 i have is a 20".
micro48
Images: 0
Postby kytekeith » Jan 19, 2010 5:57 am
Lucky man , glad to hear you don't have to replace the core.
kytekeith
Images: 2
PreviousNext
  • Advertisement
KMCustoms.com
Return to The Hydrostream Forums Lounge
