I have 2 new Braille batteries, the boxes have been opened but not used. They have been tested at 380 cranking amps and weigh only 6.9 lbs.
$140.00 shipped each
• Easy Install: Direct Group 9 Drop In Replacement
• Faster: Up to 40% Lighter, Less HP Loss
• Safer: Sealed Safe Design, Non-Spilling
• Efficient: Stable Voltage Output, Less Stress on Alternator
• Greener: Constructed from Premium Recycled Materials
• Reliable: Individually Certified, Racing Warranty, Made in USA
PHYSICAL SPECS
Replacement Group: “9”
Length: 5.8” / 150 mm
Width: 3.4” / 88 mm
Height: 4.2” / 106 mm
Minimum Weight (lbs): 6.9 lbs / 3.1 kg
Terminals: Vertical or Horizontal 6 x 1.0mm
Auto Posts: TrueTorque SAE Auto Posts
Polarity: Left Positive
Recommended Mounts: Braille “1018” or “211”
PERFORMANCE
Voltage Class: 12 volts
Full Charge Range: 12.8-13.2 volts
Max Amps: 760
Pulse Cranking Amps: 527
Cranking Amps @ 32F: 283
Cranking Amps @ 0F: 210
Nominal Capacity: 10 AH Braille B106 Model Shown
Internal Resistance (ohms): < 15.8 milliohms (.0158ohms) w/ TrueTorqueTM Terminals
Life Cycle @ 10% DOD: Up to 2000 cycles attached
CHARGING INFORMATION
Alternator: Automotive, Marine and Cycle Compatible
Battery charger: Braille Model 1232, 1236, 12310, &12325
Rapid Recharge: Yes, 10 amp/hr electronically controlled
Maximum Charge Voltage @70F: Up to 14.8 volts
Recommended Charge Voltage: 14.4 – 14.8 Volts
Braille no weight batteries 6.9lbs
- 15424 Views
Mar 17, 2019 7:47 pm
- 21Replies
- 23773 Views
May 09, 2019 9:16 pm
- 10381 Views
- Last post by deauboy
Dec 28, 2019 12:06 pm
- 10348 Views
Mar 02, 2021 6:09 pm
- 9452 Views
Apr 05, 2019 9:22 am
