Page 5 of 7
Posted: Mar 17, 2013 3:10 pm
by bhbestcustoms
Wow guys! Thanks for all the great posts and the very nice pic's. I love the green '74 Vector, it has an old mustang vibe to it, very cool!
Sorry that we have been away so long, it has been a long old winter and we are getting anxious to get started with some more work on the re-build. Attached are some more pics from last year and we have a few questions for you if you don't mind.
This picture is of the fusebox that was located half way between the engine and the ignition/throttle control. When we opened it up it is pretty rough. There were wires that were not even capped off and the two relays are pretty rough looking. I'm surprised the boat even ran at all. Once we had some problems lowering the motor and I happened to hit this box with my hand and it started working again.
I'm not sure if we can rebuild it or if we should just see how much a new one would cost and buy the new trim relays as well.
What have the rest of you done?
The next couple of pictures are of the ignition/throttle control and you will notice a dial that is attached to a spring structure. When we turned this dial when we were operating the boat it did'nt seem to do anything, does anyone know what it is suppossed to do? The other thing is it appears that someone added a blue wire to fix a problem that they may have been having. You can see the wire in the next three pictures below from where it enters beside the dial and goes underneath the spring part along to a small cylinder shaped item. Anyone have any ideas why? or if it is ok to leave as is? Its just that if we have the control out of the boat if there is something we need to upgrade or replace, now would be the time to do it. We are very happy to receive your expertise and suggestions, keeping in mind my high school student budget.
Posted: Mar 17, 2013 3:41 pm
by bhbestcustoms
Posted: Mar 17, 2013 3:46 pm
Glad to hear your going to be back at it! We are going to be getting some snow late tonight and into tomorrow as well. I am about ready for this to be over with already. I have a boat I want to get done.
Posted: Mar 17, 2013 6:55 pm
So happy to see you got rid of the rollers on that trailer! They are so bad for our boats.
I would put another set of bunks on there personally so you have a total of four of them. Better support for the boat. and especially if you plan to recore it on the trailer.
Posted: Mar 17, 2013 7:38 pm
by frogII
bhbestcustoms wrote:Wow guys! Thanks for all the great posts and the very nice pic's. I love the green '74 Vector, it has an old mustang vibe to it, very cool!
The little thumb screw with a spring is throttle friction , so you can let go of the throttle and not hvae it go back to idle ( OMC cruise control
the black disk with wires attached is the alarm horn ( over heat )
the black box with the relays and misc wires is for trim & tilt , I have an 1982 in the garage with the same thing , I can get pics if needed.
other than that I like the original red much much better , looking good keep at it
Posted: Mar 17, 2013 7:52 pm
by bhbestcustoms
Hippie459MN wrote:So happy to see you got rid of the rollers on that trailer! They are so bad for our boats.
Thank-you for your advice! I will definately put another set of bunks of which I agree will make it much more stable for recoring it on the trailer, I was quite concerned about that. Thank-you!
Brad
Posted: Mar 17, 2013 8:11 pm
by bhbestcustoms
frogII wrote:The little thumb screw with a spring is throttle friction , so you can let go of the throttle and not hvae it go back to idle ( OMC cruise control
So if the throttle spring is not set and we let go of the throttle it would just return to idle? If this is correct I guess we can presume that we have it set correctly, or is it supposed to return for safety reasons or just a preferece setting?
How do we know the over heat horn is working? One time when we were out the engine just died and I thought we were out of gas but discovered we were just getting low, like around a quarter of a tank. I pumped up the gas pressure pump and it restarted but it scared me that we might of been pushing the engine too hard as we were floared at the time. We seemed to be fine after that as we still went for another couple of hours and changed tanks without another issue.
If not too much trouble I would love to see some pictures of the black box you have, it will help us ensure we put ours back together the right way especially, as it has been a couple of months since we took it out of the boat.
We like the original red too but it depends how much repair is needed to restore it.
Lastly, Thank-you so much for your help. We really appreciate it!
Brad
Posted: Mar 17, 2013 10:25 pm
by VultureNo2
Looking Good. Keep on posting. Bill
