Faster Prop for V-King
Sometime in the past my V-King was repowered with a 200 Yami. The Yami was previously on a grew 186, not a race boat.
So the current prop is a high five 13.25" -23P. As you would expect, the holeshot is awesome, but the top end isn't. The boat has a hydraulic jackplate (5.5" offset), but no low water pick-up.
I am not chasing miles per hour. Just something more appropriate.
What prop would be appropriate on a 200 hp V-King?
Re: Faster Prop for V-King
I like a 26 et for all around performance but I run mercs.
Money was never a big motivation for me, except as a way to keep score. The real excitement is playing the game.
Wilson
Wilson
Your lower unit will limit how well a performance prop will run, ideally you want to surface a chopper on a V-King. Maybe look for a 26" laser 2, that might be a good compromise
How the boat is used will determine the prop recommendation.
Family boat? By yourself just buzzing around? 4 bimbos pulled on a tube?
Without a low water pick up you're going to be very limited on performance props. ET's, SRX's and choppers, all work great on a Viking but will need a low water pickup. I would look into a Trophy or Tempest probably around 26" pitch and run it as high as you can without loosing water pressure. This should get you well into the 70's if not over 80.
Every hull and set up is a bit different and requires testing, so you'll end up buying/selling lots of props. I went through 8-10 before finding exactly what the boat likes. If you're lucky some guys in your area will let you borrow some to run. Some dealers will allow you to take a prop and test it with a deposit.
Like said above it will depend on what you're looking to do with it. I have a few props laying around for different outings.
With all that said to get the most out of the boat you'll need a low water pick up to get the motor up higher. Under those circumstances my boat loves an ET.
Tony.
Tony.
I see a Mercury Tesmpest plus prop for sale in my area.
It is 14.625 X 27 pitch.
The current prop is 13.25 X 23 pitch.
Is this too much prop? The larger diameter concerns me.
I got the 27" pitch Tempest prop. It is allot faster. 60 mph with lots of throttle left.
Why only 60 ? Because I got scared. The boat starts gentle rolling side to side at that speed.
Is this likely a set-up issue, or do I need driving lessons? Anyone got some advice?
The boat has new core, stringers and floor.
The soft transom will get repaired this winter (the other reason I didn't push it).
- Has thanked: 351 times
The transom could be the reason. Whats your set up like? Set back, motor height (prop shaft to pad), nose cone with low water pickup?, etc....
I do not have a lwp or nose cone. The prop shaft centerline is about 5' below the pad. I experimented with it up about 2" from there and 1" down from there.
When I got it back on the trailer I tried to wiggle the motor side to side and found some slop (hydraulic steering). This seems like a possible problem. Probably not bled well enough when I rerigged the boat.
Mostly I have read about people with porposing issues. Is this side to side roll unussual?
How do you measure setback? Thickness of the jackplate or distance from cone to pad or other?
evinrude 235 hp crossflow lower unit removal/replacement
Last post by mitchielpricer « Feb 24, 2014 6:55 pm - 4Replies
- 4287 Views
- Last post by bruzercomp81
Feb 25, 2014 11:20 pm
- 8943 Views
Apr 07, 2014 9:10 pm
- 22449 Views
Apr 07, 2014 9:15 pm
- 5134 Views
- Last post by Rollo1968
Mar 17, 2014 9:27 pm
- 9463 Views
Apr 03, 2014 11:06 am
